Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Replacement keypad part numbers (590+ / 690+ / 890 / AC30 / AC10)
  • AC/DC Industrial Drives-
    • AC15/AC20
    • DESAT (OVER I) Fault
We offer the following parts for replacement needs for the 590+, 690+, 890, AC30 and AC10 products.
590+, 690+ and 890 (frame E-J for 890)
6901/00/G   = Keypad replacement kit
Note - Includes a replacement keypad and the 1" connection cable that is used when the keypad is mounted on the drive directly.  This keypad can be used with all 590+ and 690+ drives.  It can also be used with 890 drives.  The 6901/00/G can be mounted directly to 890 drives frames E-J and also to the 890PX.  It cannot be mounted to 890 drives frames B-D.  The 6901/00/G can be used with all 890 drives as a remote keypad.
Additional Note - The previous version of the keypad replacement was 6901/00 and it was blue in color.  The product line color scheme was updated to Parker colors and the current keypad is 'gold' in color now but functionally the same as the older 'blue' version, which is no longer available.
CM389812   = 1" connection cable only
Note - No keypad included.
6052/00/G   = Remote Mounting Kit
Note - Used to remote mount the keypad on the cabinet door or elsewhere, not directly on the drive - includes mounting hardware and 3m connection cable but does not include the keypad itself.
CM057375U300   = 3 m connection cable only
Note - No mounting hardware or keypad included.
890 (frame B-D)
6511/RS232/00   = Keypad replacement kit
Note - This keypad is the one that mounts directly to the 890 B, C and D frames, which are too small to accommodate the larger 6901/00/G.  This keypad can be mounted remotely if desired and ships with a gasket and two mounting screws for that purpose.  Cable CM057375U300 can be used to connect it to the 890.  However, for remote mounting purposes, the 6901/00/G is usually preferred because it has a full text display and more features.
Note - The 1" cable used on the 6901/00/G is not required for this keypad.
AC30
7001-00-00   = IP54 graphical keypad
LA501991U300   = Keypad remote mounting kit
Note - Used to mount the keypad on the cabinet door or elsewhere, not directly on the drive - includes 3 m cable and screws (nothing else required) but does not include the keypad itself.
7001-01-00   = Keypad blanking cover
Note - This can be used to take up the space left over if a keypad is not installed on the drive.
AC10 (IP20)
1001-00-00  = Remote keypad w/ 1.5m cable and mounting brackets
Note - The remote keypad works for all IP20 AC10 drives (models starting with "10G-").  It can also be used to replace the built-in keypad for frames 6-11 as this keypad is removable.  Frames 1-5 cannot have their built-in keypad replaced because it is not removable, but there is a connection port on the side of the Frame 1-5 drives for the remote keypad to be plugged in and this will then disable the built-in keypad.  If the built-in keypad fails, this can be a way to "replace" it by using a remote one instead.
1001-01-00   = Extension cable (1.5 m) only Not Offered
AC10 (IP66)
1601-00-00  = Remote keypad and extra screws
Note - Works for all IP66 AC10 drives (models starting with "16G-").  It can also be used to replace the built-in keypad for all frames as this keypad is removable on all IP66 frames.
1602-01-00  = Extension cable (1.5 m) w/ sealing glands
Pricing, availability, and ordering is available via a local distributor.  Email emn.service@support.parker.com with your zip code if you need a local distributor contact.
glh   6/2021
16JUN2021 DCLIFFE -- Expanded.
2/2023 glh AC10 clarifications
  • 6901
  • 890PX
  • 6511
  • AC10
  • AC30
  • 590+
  • keypad
  • 690+
  • 890
