Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Legacy Product Page - P1 Series
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
Introduction
The P1 series was a line of DOS-based HMIs running Parker CTC's Interact runtime software. There were many variants of the P1, the only one of which still available is the P13.
Models
The following models are covered under this series:
  • P11-*
  • P12-*
  • P15-*
  • P1H-*
  • PMP-*
Replacement Options
For most P1 models (P11, P12, PMP, P1H), the best replacement is the P13 [ Product Page ]. For the P15, the best option is the PA210 [ Product Page ]. There are a few exceptions to this:
  • Units with PC/104 cards installed (e.g. Allen-Bradley Blue Hose communications card).
  • Units running custom software beyond the Interact runtime. Occasionally, certain machine builders would install additional software on the P21 and use it to do things outside Interact's capabilities. This is very rare.
  • Applications that use a printer. Printers are no longer supported.
We recommend talking with Parker or your distributor before attempting an upgrade.
Related Articles
Documentation
Model Number Manual Title Manual Part Number Revision Date File Size
P11-TOUCH P1 Touchscreen A3-04983-100 4/97 111KB
BLR-6050 P1 Backlight Bulb A3-04986-100 4/97 226KB
P11-X1XDR-3 P1 User Guide A3-05087-101 4/98 1.0M
A3-05087-102 3/99 1.0M
A3-05087-105 11/99 1.1M
P1X-2000 P1 Compact Flash Installation Replacement A3-05565-100 10/99 10KB
P1X-PC104 P1P PC/104 Installation Guide A3-05741-100 5/99 66KB
A3-05741-101 2/01 56KB
P11-X1XDR-3 P1 Release Notes A3-06029-100 2/00 5KB
PMP-X1XDM MotionPanel QuickStart Guide A3-06165-101 9/00 141KB
A3-06165-102 3/03 127KB
PMP-X1XDM MotionPanel User Guide A3-06166-100 9/00 970KB
A3-06166-101 3/03 691KB
P12-X44DR P1 Pentium User Guide A3-06170-100 1/01 883KB
P1H-X14DR P1H Instruction Sheet A3-06190-100 10/00 5KB
MOD-5160-H/PP1-5161-K P1H Upgrade Instructions A3-06191-100 2/01 111KB
A3-06191-101 4/03 91KB
P12-X44DR P1 P Touchscreen Install. Guide A3-06205-100 2/01 235KB
DSP-1004 Display Replacement A3-06240-100 2/01 78KB
A3-06240-101 7/02 85KB
N/A P1 10" User Guide A3-06509-100 4/02 473KB
BLR-6051 P1P STN Backlight Replacement A3-06547-100 7/02 68KB
N/A P1-10" PowerStation Release Note A3-06609-100 3/03 16KB
09JUL2021 DCLIFFE
  • p12
  • INTERACT
  • p1h
  • P11
  • CTC
  • P1
  • pmp
