Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Legacy Product Page - P3, P4, P5 and P7 Series
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
Introduction
The P3, P4, P5 and P7 series were lines of DOS-based HMIs running Parker's Interact runtime software. While they all had similar software and a similar hardware architecture, each series had a few differentiating features. A summary of each series, taken from old PowerStation literature, is shown below.
Models
These series covered all models with model number format P31-*, P41-*, P50-*, P51-* and P71-*. Model number formats are given in the below catalog samples. These samples do not show every option ever offered, but are good references for understanding what options were installed on a unit.
Older models had a format in the style P50-21AR-A. The important thing to note is that models in this vintage may have been shipped with SIMM stick memory instead of Compact Flash, making it more difficult to recover programs from them when they fail.
Replacement Options
Many of these models can be replaced by the PA2 [ Product Page ]. There are a number of exceptions to this:
  • The P5 had a full set of physical function keys and a larger cutout. Parker no longer offers an Interact HMI with function keys. However, it may still be possible to migrate to a PA2 since function keys on the P5 were typically "mirrors" for existing touchable buttons in the Interact runtime. Contact Parker for assistance.
  • Units with PC/104 or ISA cards installed (e.g. Allen-Bradley Blue Hose communications card).
  • Units running custom software beyond the Interact runtime. Occasionally, certain machine builders would install additional software on the P21 and use it to do things outside Interact's capabilities. This is very rare.
  • Applications that use a printer. Printers are no longer supported.
We recommend talking with Parker or your local distributor before attempting an upgrade.
Related Articles
Documentation
Model Number Manual Title Manual Part Number Revision Date File Size
COV-4000 PowerStation Card Extension Cover A3-04934-102 4/98 138KB
A3-04934-103 10/98 250KB
BLR-6080 TFT Backlight Bulb Replacement A3-05183-100 4/98 32KB
A3-05183-105 9/99 90KB
P31-XCX-XX-2AX, P41-XXX-XX-2XX, P5X-XXX-XX-2XX, P7X-XXX-XX-2XX (version 105 only) PowerStation User Guide A3-05190-101 4/98 707KB
A3-05190-102 10/98 1.2MB
A3-05190-105 10/99 1.2MB
A3-05190-106 8/00 1.3MB
BLR-6090 LCD Backlight Bulb Replacement A3-05192-100 4/98 63KB
A3-05192-105 9/99 154KB
BLR-6060 STN Backlight Bulb Replacement A3-05193-101 3/98 86KB
A3-05193-105 9/99 246KB
RAM-40XX PowerStation DRAM Replacement A3-05196-101 4/98 85KB
A3-05196-102 10/98 55KB
P31-XCX-XX-2AX, P41-XXX-XX-2XX, P5X-XXX-XX-2XX PowerStation Contrast/Brightness Utility A3-05211-100 4/98 10KB
A3-05211-101 10/98 9KB
A3-05211-105 11/99 13KB
PCON-232-A, PCON-422-A, PCON-485-A 5x86 Third Serial Port Installation A3-05665-100 2/99 977KB
A3-05665-105 11/99 946KB
DIM-OXXX P2-P5 Pentium PowerStation DRAM Replacement A3-06111-100 10/00 666KB
PCOM-232(A), PCOM-422(A), PCOM-485(A) Pentium Third Serial Port A3-06229-100 2/01 904KB
05AUG2021 DCLIFFE
  • P7
  • P3
  • INTERACT
  • CTC
  • P41
  • P50
  • P71
  • P4
  • P51
  • P31
  • P5
