Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR74V ACR78V: How to Reset BiSS Absolute Encoder Position
      • 7000-
        • ACR Binary Host Interface - 7000 and IPA
        • ACR7000 and IPA - AcroBasic PROGRAM SAMPLES
        • ACR7000 Connector part numbers
        • ACR7000 Controller differences to ACR9000
        • ACR74T Stepper Power Supply Sizing
        • ACR74V ACR78V: How to Reset BiSS Absolute Encoder Position
        • BE and SM Servo Motor Speed-Torque Curves at 24volts and 48volts
        • Expanded DEFINES allows numeric characters
        • Expansion I/O Information for ACR7000 and IPA
        • P Series Servo Motor Speed-Torque Curves at 24volts and 48volts
        • Parker Motion Manager Software Computer Requirements
        • Parker Motion Manager: What's New or Different Compared to ACR-View?
        • PC to ACR Program Samples (Excel, LabView, VB.Net, C++, C#)
        • Stepper Motor and Feedback Connectors
        • Time Saving Tip: Use Axis Copy if using same motor on other axes
        • Using #DEFINE inside PMM programs
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
When using BiSS-C multi-turn absolute encoders with the ACR70000 servo (ACR74V 4axis or ACR78V 8axis), it may be helpful to reset the zero position to better align with the system mechanics.
To reset the absolute encoder position, move the motor to the desired location.
Then, in the terminal, set the Set Absolute Position parameter for the axis to 0 and issue DRIVE RES.
Example for axis0:
p28785=0
AXIS0 DRIVE RES
ESAVE
Requires DRIVE RES and ESAVE
Same as c62=0 for IPA.
keywords: p28785 BISS Home Mode 35
