Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base No motors listed in WinTips motor database?
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
When installing WinTips from our website or from Sizing CD-ROM, the shortcut placed on the desktop and in the Start Menu does not have any properties. Running from this shortcut opens the software but the motor database isn't recognized. This is a problem with the Windows installer program that created the executable. There should be a way to designate the working directory to look for files the program uses such as the database.
Workaround: Running it from or creating a shortcut from the tips.exe (default: C:\Program Files\Parker\WinTips\tips.exe) works.
