Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Training - Basics: How to Upload & Download (Video)
Click here to launch video on Youtube.
Just what you need for technicians and first time users for simple upload & download and things to be careful about that other users run into based on support requests.
Related video FAQs:
RS232 Serial Communication Troubleshooting
See product pages for more detailed video playlists on using C3 ServoManager for the different technology levels
Compax3 I10T10 Base Servo Drive
Compax3 I11T11 Simple Indexer
Compax3 I11T30 Programmable Drive Controller
Compax3 I31T11 EtherCAT Servo Drive
We've many detailed posts in this knowledgebase. To find more, use search window above.
