Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Expanded DEFINES allows numeric characters
      • 7000-
        • ACR Binary Host Interface - 7000 and IPA
        • ACR7000 and IPA - AcroBasic PROGRAM SAMPLES
        • ACR7000 Connector part numbers
        • ACR7000 Controller differences to ACR9000
        • ACR74T Stepper Power Supply Sizing
        • ACR74V ACR78V: How to Reset BiSS Absolute Encoder Position
        • BE and SM Servo Motor Speed-Torque Curves at 24volts and 48volts
        • Expanded DEFINES allows numeric characters
        • Expansion I/O Information for ACR7000 and IPA
        • P Series Servo Motor Speed-Torque Curves at 24volts and 48volts
        • Parker Motion Manager Software Computer Requirements
        • Parker Motion Manager: What's New or Different Compared to ACR-View?
        • PC to ACR Program Samples (Excel, LabView, VB.Net, C++, C#)
        • Stepper Motor and Feedback Connectors
        • Time Saving Tip: Use Axis Copy if using same motor on other axes
        • Using #DEFINE inside PMM programs
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
As of firmware update 7.50 update1 for the ACR7000 (controller, servo or stepper), DEFINES has been expanded to allow numbers.
For many users incorporating the axis number within the name, this can allow a shorter name and less typing when programming.
Note the number acts as a delimiter and the text before the number cannot be a reserved word (command) such as BIT or AXIS or MASTER and will cause an UNKNOWN COMMAND error. Users can see the list of reserved words by typing HELP in the terminal emulator or seeing the HELP command in the online help.
Version PMM 2.3 will flag these in the message window before downloading:
Note that PMM 2.2 and prior versions does not incorporate this check and though allows downloading to the controller will cause UNKNOWN COMMAND when used
Note this firmware change is only for the ACR7000 series and has not been incorporated into the IPA yet.
