Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - C3ServoManager - Saving Help Files During Upgrade or Reinstall.
During a new installation or reinstall of C3 ServoManager, the help files will be removed. Please note, the purpose of removing old helpfiles is to make sure the customer has the latest helpfiles installed.
REMEDY
If you wish to retain your old helpfiles copy the following directory where they are installed. They typical installation directory is C:\program files\Parker\DB\. Copy before installing new directory, then paste folder into new install.
