Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Drive Connector Part Number Incorrect in rev A of User Manual
The original manufacturer 3M connector part number is incorrect in rev A of the Pseries Indexer Drive on page 48 (page 50 of 316 of the pdf).
The correct part number is 10150-3000PE  (3M)
It is listed incorrectly as 10120-3000PE  (3M)
