Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC Terminal Discontinued - PTA, PTI, PTL
All variants of the PAC Terminal due to availability of components as of July 2022. The part numbers included are as follows:
 PTI-007-1R2-40
 PTA-007-1R1-13
 PTA-007-1R1-15
 PTA-010-1R1-13
 PTA-010-1R1-15
 PTA-015-1R1-13
 PTA-015-1R1-15
 PTL-007-1R1-13
 PTL-007-1R1-15
Migration Path
Parker does not offer any direct or indirect replacements for the PAC Terminal. Potential options to consider would be:
  1.  Use a generic PC running a browser like Chrome or Edge, which would require no changes to the PAC project
  2.  Incorporate a design change in the project to incorporate Modbus/TCP and develop an Interact Xpress application also using Modbus/TCP to exchange data with the PAC project. It is important to note that the cutout dimensions of the comparable XTA panels are the same as the PTA panels.
8/5/22jh
