Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Troubleshooting - IOCTL NDIS REBIND ADAPTER error on XT
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
This fault can occur on new XT HMIs if users have taken the SD card out of the back of older revision XTs.
This error occurs when trying to set the IP address in Network Settings from the shell.
Use the SD card it shipped with or do a flashback on the SD card and then use Xpress 4.2 to transfer the project (to the SD card with a reader or to the XT after setting the IP address).
Related FAQ:  Interact Xpress Troubleshooting - XT replacement panel won't connect over ethernet
8/9/22jh
