Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - Environmental specs for PS cables
The PS cables are rated up to 105 degrees Celsius. Above this temperature, the insulation will melt.
The PS connectors are rated IP65.  The PS connectors themselves are rated for -20C to 130C operation.
