Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - What is the Compax3 resolver frequency (X13)?
When using a third party resolver motor, the drive and motor must be able to use compatible resolver frequencies. The Compax3 resolver excitation frequency is 8kHz.
