Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Cables - Direct Drive Motor Cable Change
Due to lack of availability of the raw cable, new part numbers will be introduced, and the existing cables will no longer be available, effective immediately.
Change Description
Parker is discontinuing the motor cables for the P Series Direct Drive Motors and introducing new cables as the replacement. The change is effective immediately.
Cable Length (m)
Obsolete (orange jacket)
Replacements (black jacket)
3
APCS-PN03YS
APCS-PF03YS
5
APCS-PN05YS
APCS-PF05YS
10
APCS-PN10YS
APCS-PF10YS
20
APCS-PN20YS
APCS-PF20YS
 Change Reason
The raw cable previously used for the motor cables is no longer available from the supplier.
Change Impact
The new cables are considered form, fit and function replacements with no changes to the motor performance. The cables are black as opposed to the orange of the original with the same motor mating connector. The replacement cable has a strong track record, having been successfully used in the P Series rotary motors for years. Encoder cables are not impacted by this change and have the same part numbers.
Ref: SB1959 Oct 6, 2022
FAQ posted 10/14/22jh
