Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Troubleshooting - TASF Bit 26 -- Motion Suspended
This bit is activated when change in motion is suspended pending GOWHEN (YES/NO). Command processing will not be suspended but motion will. This bit is cleared if the GOWHEN condition is true, or if STOP (!S) or KILL (!K or ^K) is executed.
REMEDIES
1)Review program to determine where GOWHEN is used.
2)Use the TRACE1 program to follow code execution to determine why state required for GOWHEN does not become true.
