Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base TASX Bit 22 -- Unrecognized Hardware Detected
This bit will activate if a Gemini Operating System (OS) that does not support Profibus or DeviceNet is loaded into a Gemini unit which contains the Profibus or DeviceNet hardware option. Older Gemini OS revisions will not recognize these hardware options.
REMEDY:
Download the most current Gemini Operating System that supports the hardware option contained in the Gemini unit in question.
