Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base TASX Bit 23 -- User Fault Input Active
This status bit activates when the User Defined Fault feature has been activated on the Gemini product used. For GV/GT drive users, see the description for Input #3 (Pin 31 on the DRIVE I/O connector) in the Specifications Section in the Hardware Installation Guide for the respective Gemini drive. For GV6/GT6 users, see the INFNC-F command description in the Gemini Series Programmer’s Reference.
