Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Troubleshooting - BDM Display shows "Load Menue!"
Symptom: BDM01/01 displays:
Load Menue! v2.2
Symptom: The status bar scrolls constantly. No button functionality.
Cause: The Compax3 configuration downloaded does not include the BDM support.
Fix: Go into the Compax3 Servo Manager > Download (PC -> Compax3) > BDM Menu Data and select the appropriate language.
Note this menu data is downloaded to Compax3's at the factory before shipment.
Downloading different configurations to the Compax3 does not erase the BDM Menu Data.
Updating the Compax3 firmware package does erase the BDM Menu Data.
