Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Accessories - BDM Editing Move Profile Table for T11
The BDM cannot edit move profiles in move index chart nor can you make motion.
It has three major functions:
1. An upload and download to copy programs from one C3 to another
2. Display various objects including but not limited to: drive status (any faults), position (actual and commanded), velocity.
3. Edit motor tuning parameters.
As PC's are fairly common, editing the move chart should be done through the software. The BDM is a meant as a simple device for copying one setup from a drive to another and readouts and tweaking the motor parameters.
However, variables in the recipe table for the T30 and T40 can be changed through the BDM.
