Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - EMC Compliance
For the Compax3:
The NFI01/01 for the S025 and the S063 AC Mains Filter.
The NFI01/02 is for the S038/075/150.
The NFI01/03 is for the S300.
Standard Compax3 without filter meets EMC Class A.
With the filter, meets Class B.
Both require cables less than 10m.
