Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Hall-only Commutation
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)-
        • Hall-only Commutation
        • Meaning of the Status LEDs
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
It is possible to use the Aries with a motor that only has Hall Effects and no encoder. The drive is now a trap-drive and not a sinusoidal drive as it is when using an encoder.
To set it up, OHALL must equal 1 for Hall-only trapezoidal commutation. If you're not using an encoder at all, then be sure to set SFB to 2.
