Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - Changing Gear Ratio on the Fly with the T11
If you want to change the gear ratio on the fly, you can use I12T11 and put a different gear ratio in the profile table. With the digital input, you can select the desired ratio. The gear ratio cannot be changed on the fly with the I10T10.
