Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPM Motors - Trap Option: Use Sine as a Drop-In
The MPM motors had a trapezoidal option and a sinusoidal option. The trapezoidal option was discontinued as these are redundant and almost all newer digital drives sinusoidally commutate the motors.
There is no difference between the sine option and the trap option, just the part number and the way the current units printed on the side of the motor.  They are the same resistance and inductance; it is only a unit conversion between Amp trapezoidal (six-state current) to Amp peak of sine wave.  Further details on the calculations for the differences are listed in this document:  http://www.parkermotion.com/new_ulm/appnotes/SINETRAP.zip
This table lists the previous standard part number and on the right, dropin replacement for ordering:
MPM Part Number with T Dropin Replacement Part Number
MPM1141ATG6G1N MPM1141ASG6G1N
MPM1141ATG6G1R MPM1141ASG6G1R
MPM1141ATG6G3N MPM1141ASG6G3N
MPM1141ATG7G1N MPM1141ASG7G1N
MPM1141ATG7G3N MPM1141ASG7G3N
MPM1141ATG7G3R MPM1141ASG7G3R
MPM1141ATG7JM1N MPM1141ASG7JM1N
MPM1141BTG6G1N MPM1141BSG6G1N
MPM1141BTG6JN1N MPM1141BSG6JN1N
MPM1141BTG7E1N MPM1141BSG7E1N
MPM1141BTG7G1N MPM1141BSG7G1N
MPM1141BTG7G1R MPM1141BSG7G1R
MPM1141BTG7G3N MPM1141BSG7G3N
MPM1141CTJ6E1N MPM1141CSJ6E1N
MPM1141CTJ7G1N MPM1141CSJ7G1N
MPM1141DTJ7G1N MPM1141DSJ7G1N
MPM1142ATG6G1N MPM1142ASG6G1N
MPM1142ATG6G1R MPM1142ASG6G1R
MPM1142ATG7G1N MPM1142ASG7G1N
MPM1142ATG7G1R MPM1142ASG7G1R
MPM1142ATG7G3N MPM1142ASG7G3N
MPM1142ATG7G3R MPM1142ASG7G3R
MPM1142ATG7JM1N MPM1142ASG7JM1N
MPM1142BTG7G1N MPM1142BSG7G1N
MPM1142BTG7G1R MPM1142BSG7G1R
MPM1142BTG7G3N MPM1142BSG7G3N
MPM1142BTG7JN1N MPM1142BSG7JN1N
MPM1142CTJ7G1R MPM1142CSJ7G1R
MPM1142CTJ7JN1N MPM1142CSJ7JN1N
MPM1142DTG7G1N MPM1142DSG7G1N
MPM1143ATG6G1N MPM1143ASG6G1N
MPM1143ATG7G1N MPM1143ASG7G1N
MPM1143ATG7G3N MPM1143ASG7G3N
MPM1143ATG7G3R MPM1143ASG7G3R
MPM1143ATG7JN1R MPM1143ASG7JN1R
MPM1143BTG7G3N MPM1143BSG7G3N
MPM1143CTJ6G1N MPM1143CSJ6G1N
MPM1143CTJ6G3R MPM1143CSJ6G3R
MPM1143DTJ7G1N MPM1143DSJ7G1N
MPM1421ATG7G1N MPM1421ASG7G1N
MPM1422ATG7G1R MPM1422ASG7G1R
MPM1422BTG7G1N MPM1422BSG7G1N
MPM1422DTJ7JN1N MPM1422DSJ7JN1N
MPM1423ATG6G1N MPM1423ASG6G1N
MPM1423ATG7G1N MPM1423ASG7G1N
MPM1423CTJ7G1R MPM1423CSJ7G1R
MPM1424ATG7G3N MPM1424ASG7G3N
MPM1424CTJ7JN1N MPM1424CSJ7JN1N
MPM1424DTJ7G1N MPM1424DSJ7G1N
MPM1424DTJ7G1R MPM1424DSJ7G1R
MPM1901ATG7G1R MPM1901ASG7G1R
MPM1903CTJ7G1N MPM1903CSJ7G1N
MPM662ATF6JM1N MPM662ASF6JM1N
MPM662ATF7G1N MPM662ASF7G1N
MPM662BTG6G1N MPM662BSG6G1N
MPM662BTG6G1R MPM662BSG6G1R
MPM662BTG6JN1N MPM662BSG6JN1N
MPM664ATE7H1N MPM664ASE7H1N
MPM664ATE7JN1N MPM664ASE7JN1N
MPM664ATF6G1N MPM664ASF6G1N
MPM664ATF6G1R MPM664ASF6G1R
MPM664ATF6JM1N MPM664ASF6JM1N
MPM664ATF6JN1N MPM664ASF6JN1N
MPM664ATF7G1N MPM664ASF7G1N
MPM664ATF7G1R MPM664ASF7G1R
MPM664ATF7JN1N MPM664ASF7JN1N
MPM664BTF6G1N MPM664BSF6G1N
MPM664BTF6JN1N MPM664BSF6JN1N
MPM664BTF7G1N MPM664BSF7G1N
MPM664BTG6G1N MPM664BSG6G1N
MPM664BTG6G1R MPM664BSG6G1R
MPM664BTG7G1N MPM664BSG7G1N
MPM664BTG7G1R MPM664BSG7G1R
MPM891ATG6G1N MPM891ASG6G1N
MPM891ATG7G1N MPM891ASG7G1N
MPM891ATG7G1R MPM891ASG7G1R
MPM891ATG7G3N MPM891ASG7G3N
MPM891ATG7G3R MPM891ASG7G3R
MPM891BTG6G1N MPM891BSG6G1N
MPM891BTG6G1R MPM891BSG6G1R
MPM891BTG7G1N MPM891BSG7G1N
MPM892ATG6G1N MPM892ASG6G1N
MPM892ATG6G3R MPM892ASG6G3R
MPM892ATG6JN1N MPM892ASG6JN1N
MPM892ATG7G1N MPM892ASG7G1N
MPM892ATG7G3N MPM892ASG7G3N
MPM892ATG7JN5N MPM892ASG7JN5N
MPM892ATG7JN5R MPM892ASG7JN5R
MPM892BTG6G1N MPM892BSG6G1N
MPM892BTG6G1R MPM892BSG6G1R
MPM892BTG6G3N MPM892BSG6G3N
MPM892BTG7G1N MPM892BSG7G1N
MPM892BTG7G3N MPM892BSG7G3N
MPM893ATG6G1N MPM893ASG6G1N
MPM893ATG7G1R MPM893ASG7G1R
MPM893ATG7G3N MPM893ASG7G3N
MPM893ATG7G3R MPM893ASG7G3R
MPM893BTG7G1N MPM893BSG7G1N
MPM893BTG7G3N MPM893BSG7G3N
MPM983ATG7G3N MPM983ASG7G3N
Note the MPM40 and MPM72 frame sizes are no longer available.
If you have spares, the part number on the right can be used as replacements.
For new replacements, we'd recommend contacting your local Parker Automation Technology Center (ATC) distributor to discuss the machine requirements and investigating the SM16 or BE16 as potential replacement for the MPM40, or the N070 as potential replacement for the MPM72.
MPM Part Number with T Replacement Part Number
MPM402CTF7G1N MPM402CSF7G1N
MPM721ATE7JX1N MPM721ASE7JX1N
MPM721ATE7JX1R MPM721ASE7JX1R
MPM721ATF7WM2N MPM721ASF7WM2N
MPM721ATF7WM2Q MPM721ASF7WM2Q
MPM721BTG7G1N MPM721BSG7G1N
MPM722ATF7WM2N MPM722ASF7WM2N
MPM722CTG7G1N MPM722CSG7G1N
MPM723CTG7G2N MPM723CSG7G2N
MPM724BTG7G1N MPM724BSG7G1N
MPM724BTG7G1R MPM724BSG7G1R
MPM724BTL7JM1N MPM724BSL7JM1N
1/10/16jh part numbers added
