Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PC Card Controllers (Discontinued)
      • 9000 (Legacy)+
      • PC Card Controllers (Discontinued)-
        • ACR Controller Fuses
        • ACR Controllers: Connector Part Numbers
        • ACR1000 Support
        • Drive Enable differences: 9000 vs Bus-Based
        • Replace obsolete controllers
        • Unable to re-connect to ACR ...
        • Upgrading from ACR8020 to ACR9000 Part1
        • Upgrading from ACR8020 to ACR9000 Part2
        • ACR controller cards that do not have 64 I/O
        • ACR Controller Communication Performance
        • ACR controller require stable voltage
        • ACR to Compumotor drives -- Resistor packs
        • ACR1500 Connection To PLC
        • ACR1505 and ACR1500 Opto boards
        • ACR2000 Green LED blinks ON and OFF
        • ACR8020 driver OS supported
        • ACR8020 Expansion
        • ACR8020 requres 3.3VDC and 5VDC
        • ACR8020/1505 with MS-DOS applications
        • ACR8K WinNT driver with NT real-time extensions.
        • AcroLib Samples
        • Acroloop with Linux
        • Acromill and Acrocut for DOS Memory Requirements
        • Acroview Alias Names In PLC Programs
        • Analog output(s) stuck at -1.3VDC
        • Battery for the ACR1200, ACR8010, and ACR2000PS
        • Can I use Windows ME to run my Acroloop cards?
        • Can older firmwares be loaded onto a ACR2000?
        • Comm Error 6 using Win NT
        • Configuring for Open loop stepper
        • Connector Part Numbers - RBC, RBD
        • Encoder gate array update
        • Encoder with external power
        • Error 31 Bad Flowfile encontered
        • Error Message 7 in event log
        • Field replacement of the ACR8010
        • Firmware upgrade for ACR8000 Controller
        • Firmware Version 1.18.04 to 1.18.06
        • Firmware Version 1.18.06 to 1.18.07
        • How do I disconnect from an ACR controller?
        • How do I use the ACRXPC.OCX control?
        • Intelligent I/O Controller
        • Is ACROWNT.DLL compatible with .NET?
        • ISA-based controller addresses
        • Kill All Moves and
        • Legacy Product Page - Acroloop Controllers
        • Locating version of the PCI Driver
        • Multiple PCI cards in a PC
        • New 8010 has red lights on startup
        • NT Service Pack 6 Users
        • OPS8000 programming
        • Porting programs from ACR2000 to ACR1500
        • Reboot causes loss of communication (Error -16)
        • Replacing ACR ISA bus controller with ACR8020
        • Sinking/Sourcing Digital I/O
        • Static Sensitive
        • System log messages are not descriptive
        • Transferring Files in Acroview
        • Transferring Position Information
        • Upgrading from ACR1500 to ACR1505
        • Use of a Null Modem cable.
        • Using ACROWNT.DLL with Borland C++
        • Using serial communication
        • Using the Acroloop toolset with Borland C++
        • Watchdog relay function
        • What is needed for the ACR autobaud process?
        • Windows 98 and Backpack-style CD-ROM drives
PC Card Controllers
  • ACR1000 Support
  • ACR8020 Expansion
  • AcroLib Samples
  • Static Sensitive
