Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to Wire Limit Sensors to ACR9xxx and ACR7000 Controller
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
Here is an Application Note on programming Hard Limits with the ACR controllers...
Hard Limits App Note
