Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Homing Application Note for ACR7xxx/ACR9xxx Controllers and IPA Drives
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
Here is an Application Note on Homing with the ACR controllers...
Homing App Note
