Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Homing Application note for ACR9xxx controllers
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Here is an Application Note on Homing with the ACR controllers...
Homing App Note
