Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Step & Direction Output
There is a delay between Step output and the motion on the motor; the motion starts first.
PAPKA (which is a chip inside the Gemini drives) creates the pulses out like a servo loop and has a servo update rate. It could also dither even when the motor is standing still.
