Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Commenting AcroBASIC Programs
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
There are two methods of commenting AcroBASIC program code:
1. Stored Comments
- “REM” means remark
- Stored as a line in the program
- DSP “wastes” time processing the REM’s
- Needs enough memory to store code
- Can be on same line as ACR command lines
- Can be uploaded later from the controller
- Use a colon between AcroBASIC commands and comment with spaces around colon.
2. Stripped Comments
- Apostrophe character ( ‘ )
- Stripped on download by the ACR controller
- MUST be on its own separate line in programs
- The comments are missing from the code when uploaded
STORED EXAMPLE:
PLS0 ROTARY 2000 : REM pattern repeats every 2000 SRC cnts
STRIPPED EXAMPLE:
'pattern repeats every 2000 SRC cnts
PLS0 ROTARY 2000
