Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Motors used underwater or in the presence of oils
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
Maybe and Yes. Our motors have never been used in underwater applications. They are unaffected however by cutting fluids and oils.
