Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Does the motor coil float between the magnets?
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
All of the Trilogy motors have no interaction or attractive force between the coil and magnet track. Ironless motors only produce force in the direction of travel. Therefore, the coil must be rigidly attached to an external bearing support to hold it in place. It is not floating or otherwise magnetically levitated. Ironcore and Slotless motors have both an attractive force and a linear force.
