Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Power cycle required to change resolution on a G3
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
It is possible to change the resolution of the motor. This can be done by changing parameter #112. Please note that a power cycle is REQUIRED for the change to take effect. Issuing a reset command will not do the trick. This is true for parameters #110 through #122.
