Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - Gearing Setup on a T11 and T40
The “Travel Distance per Master Axis Revolution” is the ratio of master units to slave units. For example, if this is set to 1 and “Resolution of Master Axis” set to 4096, and the following ratio is set to 1 to 1. This will tell the slave that for every 4096 increments/counts of the master to go 1 slave unit.
