Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - Can I Run My Compax3 V4 with Single Phase VAC?
NO!! Because of the high ripple currents associated with single phase operation, the 3 phase, V4, version of the Compax3 must operate with 3 phase AC connected to the unit. Neither the bus capacitors nor the rectifier inside can handle these excessive ripple currents.
This true for the entire 80 - 480 VAC operating range of the Compax3 V4.
