Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Why is there a delay before motion on my Aries?
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)-
        • Hall-only Commutation
        • Meaning of the Status LEDs
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
There is a 100 millisecond delay from when the Aries Drive is enabled to the time which the drive can start the motion trajectory. The controller has to calculate the null point for the current being sent to the motor which is temperature dependent.
