Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Grades of steel used in servo motor shafts
Here is a table for the grades of steel used in the motor shafts of Parker Servo Motors.
Motor series Shaft alloy grade
N, J 1144 carbon steel
SM, BE 303 stainless steel
SMN, M 39NiCrMo3
MPM 416 stainless steel
MPP 416 stainless steel
MPW 316 stainless steel
  • MPP
  • MPW
  • SM
  • MPM
  • BE
