Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base N/J Motors - Pinout for the N092 Motor (MS18-5) Connector?
The following table is the pinout for the MS18-5S connector.
Designation
Pin Number
MS18-5S
Wire Color
"MS"/"RS" Cables
Wire Color
"GS"/"GB" Cables
Phase A A Red/Yellow Black #1
Phase B B White/Yellow Black #2
Phase C C Black/Yellow Black #3
Ground D Green/Yellow Green/Yellow
Shield N.C. Clear N.C.
Connector Information
Manufacturer: Amphenol Corporation, Amphenol Aerospace Division
Part Number: PT06E-18-5S(023) (mating cable connector)
Compumotor Part Number: 43-015834-01
