Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base N/J Motors - Difference between NeoMetric size 70mm and size 34
The NeoMetric size 34 and 70mm motors have the same electrical and mechanical characteristics. The only difference between them is the mounting flange dimensions of the motors. The N034 motors have a NEMA 34 mounting configuration. The N070 motors have a 70mm sqaure flange. Please refer to our current catalog for exact dimensions. All other specifications including speed/torque curves are identical.
