Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gemini Maximum Frequency Input and Output
The table below contains the maximum input command frequency (50 pin connector, pins 8-11) and output pulse frequency (50 pin connector, pins 14-17) for the Gemini Family:
Maximum Input Frequency (pins 8-11)Maximum Output Frequency (pins 14-17)
EncoderStep PulseIf Encoder Input UsedIf Step Pulse Input Used
GV2 MHz pre-quad encoder2 MHz2.5 MHz post-quad encoder2.5 MHz post-quad encoder
GV6N/AN/A2.5 MHz post-quad encoder2.5 MHz post-quad encoder
GV6KN/AN/A2.5 MHz post-quad encoder2.5 MHz post-quad encoder
GT2 MHz pre-quad encoder2 MHz625 KHz step pulse625 KHz step pulse
GT6N/AN/A625 KHz step pulse625 KHz step pulse
GT6KN/AN/A625 KHz step pulse625 KHz step pulse
Note: If ORES=ERES for GV, GV6 and GV6K, maximum output frequency is 8 MHz post-quad (2 MHz pre-quad).
The GV, GV6 and GV6K maximum feedback frequency (26 pin connector, pins 5-8) is 2 MHz pre-quadrature and 8 MHz post-quadrature.
(Pre-Quadrature = Per Channel)
