Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Configure a TCP/IP connection (DHCP)
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
Complete the following on the MachineShop Toolbar and MachineShop Shell:
MachineShop Toolbar:
  • Right click on the 'Network Neighborhood' icon on the desktop and select 'Properties'. The 'Network' dialog will appear.
  • Select the 'Configuration' tab. The list will contain several items.
  • Select the TCP/IP item for your Ethernet Network Interface Card and click on the 'Properties' button. The 'TCP/IP Properties' dialog will appear.
  • Select the 'Obtain an IP address automatically' radio button.
    MachineShop Shell:
    Using the Powerstation and the MachineShop Shell software, TCP/IP should be configured for DHCP. This is accomplished by specifying an IP Address of 0.0.0.0 in the MachineShop Shell IP.
