Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can I run Interact 6.X in Windows NT/2K/XP?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
Only the Development software can be run in Windows NT, 2000, or XP. These versions of Window have a limited DOS shell and will not support Interact runtime with any device drivers other than the DEMO driver.
