Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Troubleshooting - WinXP- cannot select options on Toolbar
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
On the MachineShop Toolbar, go to Tools, Options, and then check Always On Top, and AutoHide so that they are turned on. (Note: You must also be using Version 1.02 or higher of the MS Toolbar)
