Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base LEDs on the back of the Profibus card
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
The following table explains what indicator LED displayed on the back of the Profibus card represents.
BOTTOM TOP PROBLEM
OFF RED Node is not connected.
Another unused node has a terminator resistor that is being used.
RED RED Wires are crossed on the network.
RED Blinking GM/Red Terminating Resistor not set on I/O side.
GREEN RED Terminating resistor on PowerStation side needs to be turned on.
GREEN GREEN Working properly.
  • ISA
  • MachineLogic MCLC ISA Profibus Interact
  • INTERACT
  • LED
  • MCLC
  • MLSC
  • MachineLogic
  • Profibus
