Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How many Z-channel pulses on G2/M2 drives?
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
NOT READY: Some are 60, some are 100, some are 124...
You cannot alter the number of Z-channel pulses on the Dynaserv G2 and M2 drives. The number of Z-channel pulses for each is listed below:
DR1xxxA = 200
DR1xxxB = 124
DR1xxxE = 150
DR5xxxA = 104
DR5xxxB = 68
DR5xxxC = 52
DR5xxxE = 78
DM-A = 100
DM-B = 60
DM1004B = 124
DM1004C = 124
The manual incorrectly states parameter #358 as the number of Z-channel pulses per rev. This is actually the number of encoder pulses or motor steps per Z-channel pulse.
For example, #358 for a DRM2-1015B will show "8192". If we then multiply this number by the total of 124 Z-channel pulse per revolution, we end up with the drive resolution of 1,015,808 encoder pulses per revolution.
