Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Battery Replacement for 500 or JSI
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Smart Encoder Compatibility
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
1) Remove power from the unit.
2) Remove all other connectors.
3) Remove the four perimeter screws that anchor the front interface panel to the rest of the unit. Lift the front panel straight away from the unit. This will bring the circuit boards out of the unit. The battery is located on the control board, nearest the LED display.
4) Carefully remove the battery by sliding, not lifting. Be sure that the battery leaf spring has adequate tension to ensure the battery is not loose upon installation (bend down slightly).
5)Install the new battery, noting polarity. Reassemble the unit (lethal voltages present).
6) Return all connectors.
7) Apply power.
8) Establish RS-232C communications.
9a) 500 indexers: Issue the nXC command. Issue nRSE (where n is the device address of the unit). You should not get an error #30. Re-download your program. You are done.
9b) JSI controllers: Issue the nXC command. You will not be clear of the error #30 (EEPROM error) until you issue the nSV command to save all tuning etc. to non-volatile RAM. Re-download your program and issue nSV. You are done.
The replacement battery is a 3 volt lithium battery (Panasonic BR2032 or similar). These can be found at your local electronics store.
