Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Single layer SST 5136-PFB-104 card with Interact.
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
SST has released a new .ss1 file for the PC-104 version of the 5136-PFB card. This is a new file and has not been updated in Interact as of yet. To download this file go to the following link:
PC104profi.zip
Here you will download a file labeled PC014profi.zip. In this file is an .ss1 file and a .gse file for the card. You will have to use the .gse file in your S7 Programming for the slave and you will have to replace the PFBprofi.ss1 in the [C]:\Machshop\Interact\Drivers\PFBS directory.
  • ISA
  • INTERACT
  • SST
  • 5136-PFB
  • Profibus
