Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ERROR - Invalid Panel list or Key Pad Address.
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
The most likely cause of this error in PTM is an invalid address in your Panel List setup (under the 'Controls' Tab) or in your Keypad Setup (under the 'Entry References' Tab). You should remove one reference at the time to identify and correct the error.
  • PTM
  • Panel List
  • Invalid Address
