Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What internal variable can I use to R/W ASCII?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
The Link Variables are the only internal variables that will accept ASCII data. You must use the suffix ":A" on the link variable to allow the link variable to store ASCII data.
For example: Link\State:A = "On"
