Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to run app on my PowerStation on boot-up?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
There are settings in Interact development and on the PowerStation that need to be adjusted.
Development Settings
In Interact under the FILE menu select Interact Settings and then select your Startup Application on the General Tab. Also, in the Application Browser, Under Application Manager, Select Application Settings. Then on the General Tab under Startup Mode choose Run and make sure that you have chosen the appropriate Startup module.
PowerStation Settings
Enter the Machine Shop Shell and select Settings and then General. Then select Power Up Operation and finally select Interact.
Reboot the Workstation and the Interact application should run on power up.
edited dom 02/13/2019
  • P7
  • P3
  • INTERACT
  • PA
  • P1
  • P2
  • HPC
  • IPC
  • P4
  • PA2
  • P9
  • PowerStation Shell
  • P5
