Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AcroBasic program does not wait
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Because the ACR controllers buffer moves, the AcroBasic programs will continue to process command lines and not wait until a move is complete. A program event that is intended to occur upon move completion will be executed during the move.
An inhibit command using the In Motion flag can to be used to make the program wait until the move is complete before proceeding with the program.
Example:
INH -516          : REM  will inhibit program until In Motion flag for Master0 is clear.
